This event occurs when the server fails to send a reply using IPML send to a client request. msg: Server message name: Keychain name peer: IPML peer ID code: IPML error code
Unregister from keychain and register again. If that does not work then restart the client process or reboot the switch.
Error
Failed to send %msg% for keychain %name% to peer %peer%, IPML error code %code%.
| Name | Type |
| msg | String |
| name | String |
| peer | uInt |
| code | sInt |
